- 18 Oct 2002
- Welsh Wales
My quad is @ 3.5Ghz. I had a prime error after 4 hours,( rerun after 8 hours stable, testing my temps now the room is warmer). Nudged 1 on the vcore, had another after 6 hours (going in the right direction). Did I read somewhere that prime can error if you are browsing the web at the same time? Should I just add a notch on the vcore or does the north bridge need any more juice. If so how much and what is it's setting in the IP35 Pro's bios.
Thanks.
Thanks.
