wdEvA said:hmm so will it stil be considered stable, if u can pass 1 and fail the other?
Justintime said:Prime95 for cpu and to some extent RAM - 24hrs at least for me
Memtest86+ - RAM - 24hrs for me
3Dmark01 - 3D and general stability - looped 24hrs
No rig has given me problems hardware related that passed that.
Shocky-FM said:3 days of testing? what a waste of time... You could at least run F@H or something...![]()
But if you overclock and its fine up to a certain point/speed/voltage/latency then starts erroring with anything higher, then yes, you might've reached the peak.UKTopGun said:Why do people run say, 12 hours of prime to see if somethings stable? Surely just playing say... CoD2 for 3 hours or something will show to see if it crashes or not?
Justintime said:Your cpu may run that game for days but do something else and fall over, prime95 basically computes numbers that are known already and sets your cpu computing them and compares your computed data to the known value, any variations usually show somethings not right. So while you may think your pc is stable you might do something to trigger that instability, also funny things may happen like lost data, corrupt OS, random reboots, lockups etc.. that will manifest itself over time in a unstable rig even though on the face of it it might seem stable. Prime does a few things that overclocking needs: checks accuracy and heats things up, stresses components and drains a bit of juice since its more or less a full load on the system, so weak points may show up. Superpi is a rather short test, so instability caused by heat or undervoltage etc.. may not manifest itself in the time taken to complete it.
SP2004 "is" Prime95 v24.14 iirc. With a front end GUI, SP2004-orthos is the multicore version.wdEvA said:SP2004? how's it compared to prime?
No, I just ran Quake 4 for a laugh and the cpu didn't even get warm, only a little over the idle temperature. Its not working that hard, try compressing a huge zip file, or encoding. That's the sort of thing that pushes it, excluding the torture programs. S&M a good one for a quick test.UKTopGun said:Why do people run say, 12 hours of prime to see if somethings stable? Surely just playing say... CoD2 for 3 hours or something will show to see if it crashes or not?
SP2004 is Prime95 but with a full GUI with lots of handy things on it, as said there is a dual-core version of SP2004 but you can also just run two instances of SP2004.wdEvA said:how about like what Úlfhednar had mentioned? SP2004? how's it compared to prime?
