Primo Basic+ AMD Athlon X2 4800+ 2.5GHz SILENT DDR2 System
30 May 2004
Glasgow, Scotland
the gfx should be ok in that. from what i real the card uses around 70w at load. but im not 100% sure on that.
i guess it depends on what else you have in the case as well.
its using a 300w psu init?
I had an X800XL working in a shuttle with a similar power supply, but then shuttle PSU's do have a fairly good reputation. It says on the spec on the wedsite that it can handle a 7600 or 7900, and an X800 is only a little bit more power hungry than them.
But I agree it is a tough decision, I was nervous when I first put my card in, and again when I changed it for a HD3650 a week ago!
PK!
i know what you could do is buy a Electricity Power Energy Monitor Mete from the
bay. that would then give you a read out on what your system is using .
just an idea. 1 will cost you around 15 quid tho.
