"Primo Flare" AMD Athlon II X4 Quad Core 630 2.80GHz DDR2 System @ £407.98 inc VAT
The power of a quad core processor for the price of a dual core. Offering low power usage, superb multi-tasking performance and massive upgrade possibilities the Flare sets a new standard in high performance machines that do not break the bank. The AMD Athlon II X4 Quad Core 630 2.80GHz provides more processing power than even the fastest dual core processors while the 4GB of performance 1066MHz memory ensure the optimum multi-tasking experience no matter how many applications are running. The Seagate hard drives offer whisper quiet computing, massive storage capacity for all your documents and with the LG DVD Re-Writer drive the perfect way to backup your data.
Key Features
:- Amazing value with performance to rival systems costing several times more.
:- Energy saving components keeping running costs down.
:- Only the highest quality components ensuring the highest levels of reliability.
:- Massive upgrade possibilities, why not add a graphics card to turn the Flare from an office machine into an enthusiast grade gaming PC?
Key Components
:- AMD Athlon II X4 Quad Core 630 2.80GHz Processor
:- Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel
:- Asus M2N68-AM SE2 GeForce 7025 (Socket AM2+) PCI-Express DDR2 Motherboard
:- LG GH22NS30 22x DVD±RW SATA Dual Layer ReWriter
Note - Specification not exactly what you are after? Drop our friendly Sales Team a call on 0871 910 9101, they will be more than happy to help you make your perfect system.
Note - All systems are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours. The system can be supplied assembled with or without your choice of installed operating system but is supplied without keyboard, mouse, speakers or monitor (all of which are available elsewhere in this on-line store).
From £407.98 inc VAT.
ORDER NOW
Key Features
Key Components
ORDER NOW
