- 11 Dec 2005
- Cheshire
"Primo Ignition" Intel Core i3 530 2.93GHz DDR3 System @ £379.98 inc VAT
The "Primo Ignition" features a Intel Core i3 530 2.93GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 530 2.93GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
System Specification
- Case: Black Knight Case
- Power Supply: OcUK 450W
- CPU: Intel Core i3 530 2.93GHz (Clarkdale)
- Motherboard: Asus P7H55-M Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Onboard Intel GMA graphics with HDMI, VGA and DVI outputs or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Only £379.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
