- 16 Jul 2008
I bought the Primo Neo machine from OcUK a couple days ago and it arrived today. There's obviously something very wrong with it, but I can't figure out what. It bluescreens on attempting to install Windows (0x000000F4) and randomly crashes/freezes when doing other things.
I've tried:
- Installing Vista/7 both 32-bit and 64-bit (all fail with a BSOD or freeze)
- Installing to several different hard disks
- Resetting the CMOS, which cleared the preset OC.
- Running memtest86 (returned no problems)
- Running CPU BurnIn (worked fine)
- Using onboard graphics and a GTX260
- Swapped out the PSU for a higher wattage.
The BIOS reports normal temperatures on CPU and RAM - between 22 and 26 depending on ambient. Clocks and voltages are all set to auto and I checked in the current status tab and everything looks about right. Everything seems to work fine for a while when I go to install, but when it goes to start system services or finalise the install of Windows, it dies.
Do you think this really is a hardware issue, or is there something inside Windows that just isn't liking this build config? I really can't afford to ship the machine back to OcUK for testing/repairs since buying it has left me without cash for the month.
I've tried:
