PRIMO OREN SYSTEM TO FEATURE THE GEFORCE GTX 460
11 Dec 2005
Cheshire
"Primo Oren" AMD Athlon II X3 Tri Core 440 3.00GHz DDR3 System @ £499.99 inc VAT
The "Primo Oren" offers the performance needed for home and business use at a low price. The AMD Athlon II X3 Tri Core 440 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience. The Nvidia Geforce GTX 460 provides immersive DX11 cinematic graphics.
Why You Should Buy This System?
- AMD Athlon II X3 Tri Core 440 3.00GHz (Socket AM3) offers three cores for multitasking performance.
- 250GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
- Now featuring the brand new GeForce GTX 460 768MB GDDR5 graphics card
System Specification
- Case: Xigmatek Asgard - Black
- Power Supply: OCZ 500w II StealthXStream
- CPU: AMD Athlon II X3 Tri Core 440 3.00GHz (Socket AM3)
- Motherboard: Gigabyte GA-MA78LMT-US2H AMD 760G (Socket AM3) DDR3 Motherboard
- RAM: OCZ Gold Low Voltage 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Hard Drive: Seagate Barracuda 7200.12 250GB SATA-II 8MB Cache
- Graphics Card: Nvidia GeForce GTX 460 768MB GDDR5 graphics card
- Sound: ALC888B 8-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
The "Primo Oren" is designed as an excellent value computer system, with all the bells and whistles to make it the perfect first computer with powerhouse graphics.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Only £499.99 inc VAT.
ORDER NOW
Not bad, £6 more expensive than building it yourself I think? IMO worth the extra £30 to swap to the quad core and 500GB HDD though. ;)
£10.07 to build it yourself XD
But ya, I'd pay 7quid more for 500gb and £10 for more either quad core of .10 more ghz, easily OCable and unlockable to a quad.
