primo performance help
Start windows and download and install core temp and post what that shows.
It does seem bit to warm, can you check the fan speed and see if the H/S has come loose during transit.
is it stock cooler ???
if it is it needs to burn in it has a wax based thermal compound , or you could just check it is seated correctly or even change it for an aftermarket one ;)
yeah its just stock im installing windows nows seems pretty fast, yeah its correctly seatly this should have all been fine and tested as its a system buuilt from ocuk!
another problem added 2 sata drives on sata 3 and 4
sata 3 shows up the 200gbv maxtor but the sata4 does not show up in windoiws even though its working fine in bios and shows up in windows device list ??
You might need to go into disc management and have a look there as the disc might have wrong structure for windows or was this other disc new or removed from another pc.
yeah ive went into there and it says foreign disk ??
strange because this had lots of files on it and was running ntfs file system was fine when i removed out of the other system ?
Could be that the cooler isn't quite seated correctly or 1 clasp has come off in transit (quite common). Check that first, call OcUK Tech support while doing this if you're at all unsure:
0871 222 8528
Re the disks - as previous poster mentioned - access disk management in control panel and ensure the disks are initialised and formatted.
yeah its intiialised
right
it came out of another system i sold a few monthjs ago it has over 200gb of files on it now ive put it into this system it shows in windows but says foreign disk ??
any ideas?? the other one i put it was fine
