** PrimoChill @ Overclockers UK **
rjk
rjk
Caporegime
8 Aug 2007
You guys asked, we have listened.
PrimoChill is a long standing name in watercooling and over my time at OcUK we have seen the brand come and go a few times as they have only ever had a small presence in the UK market.
we now have a full and complete range of Primochill soft and hard tubing as well as fittings specially designed for acrylic tubing.
we already have a large discussion thread about it here on our forums
acrylic tubing allows you to bend the tubing to your own specification creating a cleaner looking cooling system whilst giving a really unique aesthetic.
here are some examples of how acrylic tubing and fittings can really transform your system into a real showcase for your hardware:
The great thing about PrimoChill tubing and fittings is that they come in a huge range of colours that really set your build off.
we carry all of the major colours as well as the main variants of fittings.
For more information, here is some instructional videos from the manufacturer that will familiarise you with the products.
Check out our range of PrimoChill at Overclockers UK
PrimoChill Fittings » Compression Fitting 13/10mm
PrimoChill Fittings » Acrylic Tubing 13/10mm
very very nice but would cost a fortune to replace a dual loop with it all especially at £6 a fitting
Makes me want to redo in Hardline and I'm not even finished yet ! Damn you overclockers why must you tempt us so? :D
+1 Yeah that Black/Orange build is the dogs.
rjkoneill - Aside from stick an H100i onto my motherboard Ive never done any custom water/liquid builds like this.
Would you (or anyone recommend) starting off on a smaller scale first? I would like to do a crossfire arrangement with the custom waterblocks on the GPUs also....
is the higher priced silver, shiney revolver version really brass/brass.
and not brass/aluminum like all the other?
If so - the 4pack spec, description needs changing
and the main description of all the brass/brass fittings needs changing
