Primochill Stuff
12 Mar 2005
I've got a bottle of Primochill Pure to try.
I take it I just fill the loop with it and don't need to add water or any other additives to stop corrosion or algae growth?
It doesn't actualy say anything about how to use it on the bottle.
Found the answer on the Primochill website:
**DO NOT MIX: PC PURE includes an Anti-Microbial agent, we do not recommend mixing any other anti-algae or anti-microbial agents with the PC PURE fluid, this includes Liquid Utopia. Adding additional agents will cause a chemical reaction with the agent currently in the fluid. It is not dangerous, it will just cause the fluid not to operate at maximum levels and may cause unwanted build up.
If it says on the side of the bottle "Contents: Water" and nothing else, then yes you would need to add an anti-algae compound at least. Anti-corrosion wouldn't do any harm but is only especially needed if you run mixed metals in the loop.
edit: must refresh a post before getting round to post a reply
