Prince Of Persia 2008 - Where is the graphics settings?
4 Nov 2002
England - Leeds
Hi there, please can you help, I dont know if am just being a newbie but I cant seem to find the graphics options for the new Prince Of Persia? I've looked everywhere, and the game doesnt look very good as it stands once you've installed it. I have a brand new PC and am running every game you can immagine in max graphics settings including crysis so am wanting to do the same for this game, but if your going to tell me theres no options to increase the graphics and the game has been ported from xbox to PC then I guess I'll have to uninstall it, because these jagged edges around the characters and such are like something from the early 90's lol.
Thanks in advance,
SkScotchegg:D
Have you tried the launcher? If you can't find the launcher on your desktop, look in the directory you installed the game to as it will be in there.
Yes in the install directory I found this:
PrinceOfPersia_Launcher.exe
doesnt do anything different from the normal exe, just launches the game?
SkScotchegg:D
Should defiantly be able to change the graphical setting through the launcher because that's how I did it. :s
Actually just found a Launcher.exe in a sub folder called Launcher, so never mind, worked it out now.
Thanks for ya help anyways,
SkScotchegg:D
