basically,, i got the prince of persia triple pack, containg all three of the mroe recent games. played through snads of time, everythihng was fine and dandy. great fun. so, i then went on and installed warrior within after completing the first game. when i started playing it was running at about 3 times normal speed.
tried it with both vsync enabled and disabled, and tried changing my verclock, and running at stock speeds. Went back to try SoT, and the same problem affected it. At that itime I was thinking something strange had happened. thinking it might have been something to with having updated windows and installed Ie7, i ran a system restore, and uninstalled warrior within and reinstalled it. no luck.
After trying this, i leant my cd to my mate, who has a laptop, and she has run into the exact same problem, just with SoT.
My system specs are as fllows, in case you can think of anything else that may be a problem, but as i said, initailly SoT ran absolutely perfectly.
E6600 @ 3.2GHz
2GB G.skill HZ 6400 at 800mhz
X1900Xt 256MB at stock
Creative X-Fi Xtrememusic
Gigabyte DS3
anymre info can be provided if need be.
cheers.
E6600 @ 3.2GHz
Gigabyte DS3
cheers.
