Print 4 Images Per A4 Sheet With Filenames
16 Dec 2003
Halifax , UK
Looking for a way to print 4 images with their relevant filenames on a single A4 sheet.
This needs to be fairly simple if possible!
Windows photo viewer lets you do a contact sheet (35 images) with filenames but they're too small, someone mentioned Irfanview but its a little too fiddly to do.
Thanks!
Faststone Image Viewer will do this.
Exit fullscreen view if it's opened in that (Enter by default), click on Create > Contact Sheet Builder > select the images you want > click on the Settings tab > change Columns and Rows to 2 > click on the Caption tab on the right side and select what you want (the default is file name without extension) > select a folder to export to (as PDF, JPEG, etc) > Create.
