Print current screen button - Excel
26 Feb 2004
Hampshire, England.
Hey guys,
I need to make a button/macro that will allow me to print what's currently in view in excel...
Any thoughts? I tried Googling a few things but none of them have worked out :(
Cheers!
Hi,
Only currently in view in Excel e.g. A Print Screen of Excel?
I haven't tried this, but SnagIT I think would allow it...
SnagIT Dev Tools
If I get a chance I'll give it ago.
Regards
Currenty Active or currently in "view"?
This will do current active:
Sub PrintCurrent()
' PrintCurrent Macro
ExecuteExcel4Macro "PRINT(1,,,1,,,,,,,,2,,,TRUE,,FALSE)"
End Sub
Or you can record it yourself. Record MAcro File > Print > Select options you want > Print > Stop Recording
Customize ribbon/Toolbar. Select macro from pulldown menu . Add to workspace.
Thanks guys! It's for printing out page 1 only, the worksheet in view...
The spreadsheet fits on screen but prints out on about 6 side of a4 with bits and pieces all over the place! Macro it is then ;)
Presumably when I do it will just look for the default printer? I ask because I may eventually pass this file on to colleagues and I don't want their file looking for my printer, if that makes sense :p
Cheers!
Hi,
To answer your question regarding the default printer. Yes, it will print to the default one.
Regards
