Print Serer USB hub
10 Dec 2003
SE1
Is it possible to use a print server as "network attached storage"? Can you daisy chain a USB hub on one?
The reason I ask is I have 3 external HDDs and hate having to leave my pc on when I wish to watch something on my laptop.
If not, is there something similarly priced that would fit the bill? I'm sort of thinking £20-30.
Thanks
ok...if anyone is interested I found that Belkin do a usb network hub (connects to your router via ethernet) but seems a little pricey at about £50.
Anyone know of something cheaper?
the netgear wgps606, depends if U can locate a recon unit, I ve a some recon units but they tend to get slight faults later on in their life like leds going out but if U could live with that then search for one otherwise check them out here at ocuk :D new is always good.
