- 29 Nov 2004
- Omnipresent
Hi all,
I need some help. I've recently deployed a print server (Win 2008 32) and i'm experiencing problems with slow printing. It seems that print jobs are taking a while to load into the spooler, whilst in most cases it's not a massive amount of time, some customers noticed (they were previously printing directly to the printers so were bound to moan!). I looked into the issue and discovered that the jobs themselves seem to be a great deal larger than the original documents.
I sent a 22kb word doc through to print and when it hit the spooler it was over 400kb? This seems to be happening with prints from all applications.
Now i understand how drivers work and knew that the jobs could potentially be larger. I am using the latest HP pcl6 drivers and so far, other than this issue they have been fine?
Now while the print jobs are larger, this does not worry me as much as the time it takes to load them into the spooler and finally print. The server is on a 100mb network and is set 100 full duplex with the switch. As far as i can see there is no network limitation, and besides, most the docs are only around 1Mb at the most? There is no firewall on the server and nothing else i can see that would interfere? I've tried enabling/disabling the render on client function but that made no difference?
Has anyone else experienced this problem or have any ideas?
Any help will be greatly appreciated!
Thanks
Thanks
