Printer Colours and Ink Left
31 Aug 2004
SGC
Just got myself an IP4200 and everything seems good apart from the colour prints. all colours seem to be neaturalised and not as saturated as the are on my screen basically to light and not as dark. I've always had this problem with printers but now I have a IP4200 I think I should try to fix it.
Also I was wondering if anyone knew if the Canons report the correct amount of ink left in the tank and if they don't is there anyway to tell without having to take the ink tanks out?
I know my Canon iP4000 is crap at display ink levels. They're either completely full or nearly empty. I thought the newer iP4200 with its chipped ink carts should be a lot more accurate.
I tried printing using the windows picture viewer instead of the canon software and everything seems fine. Strange eh.
