Printer for labels?
Caporegime
13 Jan 2010
Llaneirwg
Looking for a printer for labels.
I'm selling stuff on ebay often and doing returns etc.
Used to just go into the office.
What's out there? Ideally this will be cheap and need jam up like an ink jet.
Any ideas? Cheap and as reliable as possible!
Virtually any of the thermal ones are great, just watch the cost and size of the labels. We use Zebra at work, but they are not cheap! but then the labels are (16x1000 for like £45 last time we bought some)
Just make sure they print on a variety of label sizes, and not just the tape!
Alternatively, use the Avery labels on A4 sheets - they used to supply software where you said which row/column to start printing from so you print what you want and then re-use the sheet
I only need a 3 or 4 prints a week.
Looks like the the thermal. Ones would be ideal, but when you get to postage label size they get very expensive.
Considering a cheap Ink jet.
Cheapest inkjet you can find, maybe a HP one with instant ink? and then Avery labels is your best bet then :)
Probably the wrong end of the scale but we bought a zing/rollo/intuk or whatever sticker brand is trying to sell it currently for about £130 which came with half a roll of 6x4 thermal labels and is quite happy to take the royal mail rolls which some people sell on cheap when they shouldn't. Could use it for a few weeks while you need it for labels then sell it on after for near enough what you paid for it as the only consumable parts are the labels themselves. Doesn't take up much space, easy to store, no other consumables apart from label rolls which is much cheaper than using avery or zebra branded.
I'd just get cheap black and white laser and then print on A4 label sheets.
But thats the hard way to do it.:) I was going to do it that way, but couldnt be bothered buying the label sheets and then getting the correct template so the printer printed on the labels. So I just bought the cheapest label printer I could find that took decent sized labels.
I know Royal Mail and Hermes have built in templates for 4x 6x4 labels on an A4 page as that's what we started off with before moving to a label printer. We made the change as even on B+W the laserjet was still using colour to make up the blacks on the labels.
I just have a little dymo 450 and it works perfectly. Never had trouble with it getting jammed or anything. Picked it up second hand so pretty cheap. Its small so the label size is pretty small, but I have prebought postage on ebay and printed it with that for years. Even though it comes out small i've never had any issues with things not getting delivered. You don't need to print at the full size they give you.
In the end I've gone for a second hand
Brother HL-L5100DN
Has 58 percent drum and 30 percent toner left
Might last me a lifetime.
Was much cheaper than those dynos too.
25 quid
Apparently 40ppm. I could probably print my years worth of printing in under a minute!
Quality isn't great on prints. Might bit old or something. Think it's an old office printer or something
They look a bit faded and 'liney'
Fine for labels
If it was installed with a "compatible" drum it might have been a re-chipped recycled unit which was already beyond end of life but put back into service. Work kept buying compatibles from their stationery supplier and the print quality was terrible (printer where toner and drum were the same unit), problem disappeared when new OEM units were installed.
I guess it's something along those lines.
Yeah it wouldn't be up to the job if printing formal documents let's say
Ill use what it's got until the the barcodes are illegible.
It's main job is labels. Already saved me 10 pounds.
