Printer(silly question ahoy!)
27 Sep 2004
I have a standard Canon desktop printer(MP210, I believe) - Would it be capable of printing onto A4 envelopes without hassle?
I quite fancy printing my details onto envelopes containing resumes. I just didn't fancy cocking up my printer in the process. :p
Most printers can print onto envelopes without any issues (all my Epsons have), as basically the average envelope is no thicker/harder for it to print on than the card stock that they can usually print to.
The hardest bit tends to be remembering to load the envelope in the right way round ;)
Just print it will be fine and by the looks of it its not an expensive printer, but I have never had a printer break because of some thing I did to it they just eventually ware out over years.
I completely forgot about this thread after it was moved :p
Order yourself a stamp with your details on it mate - much less hassle and they're only a few quid.
Seems like more fuss than I was after, thanks for the suggestion though. :) It would need to be the exact typeface and sizes for stamping and I don't think there would be a stamp big enough!
After all this - the A4 envelope doesn't fit in the tray! :mad::mad: Unless I/anyone can think of a way around it, I guess I'll just have to write my details the old fashioned way.
