I've got a HP M277DW Laser Jet MFP and I'm having trouble connecting to wifi to print, it was all working fine and then suddenly it stopped printing.
I uninstalled and re-installed with the latest drivers but no go.
I can see the printer is connected to my Unifi AP but can't ping it from my W10 PC or from my W10 laptop. However, if I turn the printer off and on again then I can ping once but subsequent pings fail.
The network settings and signal on the printer are fine and it's connected to my SSID, even reset them but still the same.
I've changed the static IP but still won't print.
Firewall settings are fine (using Bitdefender).
My cartridges are all pretty new.
I've never had this problem before and I'm scratching my head! Is there anything I've missed I need to check in W10? I've had the printer for about 5 years now so I wonder if the NIC in there has gone?
