Printing envelopes with dif addresses
2 Dec 2004
Under The Desk, Wales
I have 2 A4 sized sheets on my PC with approx 40 addresses on it.
How can i select those addresses and print them off on 40 envelops without doing it manually?
They are only on 2 A4 sheets at the moment. Cheers
No, just Word document
  • Change the page size to your envelope size.
  • Set margins accordingly
  • Insert a page break after each address (shift+enter)
  • Insert 40 envelopes into your printer
  • Press print
(Edit: Test on one first to make sure you've got the orientation right)
  • Press print
this then :)
