Printing Help
15 Jul 2007
South West
Hi
Im trying to print off the manual for Civilization V that ive just bought from steam,i have the PDF file of the manual and im using Adobe Reader.
I just can not work out how to print the manual but in the format of the size of a manual,in other words i can only get the printer to printer a full A4 page,i obviously only want to print the size roughly of a manual as it over 200 pages.
Do i simply print using "Multiple pages per sheet"? or is there a different way
The is really my first printer so im hopeless at stuff like this.can anyone help that is familar with Adobe reader
Yep, multiple pages per sheet is probably the easiest way, and then select whether you want 2 pages, 4 etc
You could also do 2 sided booklet printing, but you'll need to work out the format. If you are going to do this I would suggest just printing a few sheets and see how it works before doing the whole manual.
