Printing Issue
2 Oct 2020
Hoping someone on here can help identify if this is expected when printing:
https://ibb.co/FhZXrcH
I performed 2 prints of the same item, and it did roughly the same thing in the same spot.
The printer is an Creality CR-6 SE printing with PLA - will have to check what printer settings were.
doesnt look like a Z seam, I found with my printer blobs like that were caused by back pressure or the print head having a momentary stutter but i'm using a delta on quite i long bowden tube.I used this video to help me but not sure it would work for you.
Thanks for the link I will take a look. It looks like Cura has relaxed the settings since the video was made, mine comes with:
Max Res: 0.25mm
Max Travel: 0.25mm
Max Dev: 0.025mm
