PRISM and enterprise level applications.
18 Oct 2002
Leicester
Chaps,
Is anyone currently developing WPF or Silverlight business applications with PRISM?
If so I'd be interested to hear your thoughts on it - and also if you know of any good teaching material.
Our team is taking on development and 3rd line support for various business applications built this way. So I need to get myself up to speed quickly!
I work mostly on ASP.NET MVC using DDD, Dependency Injection, etc etc... so hopefully this goes some way towards preparing me for the PRISM way of doing things - but it looks properly hardcore from what i've seen so far! :eek:
I'm currently working on a project using PRISM 4 with WPF.
We're using an MVVM pattern and PRISM 4 supports this better than the old versions, using it with Unity too, though MS seems to be pushing the MEF way of doing things a bit now.
If you've done anything with a dependency injection container before that bit should all be pretty natural.
PRISM itself has a bit of a learning curve, but it's not too bad once you get your head around the idea of a composite application.
On that front I have to say I'm not wholly convinced of the merits of a fully composite application.
Once you get beyond the simple demo applications that they provide and have menuing, workflow etc. in your application it becomes very difficult to do it in a properly composite way and then you lose some of the benefit of what PRISM provides.
In terms of learning stuff I've found the PRISM documentation to be pretty decent - not sure where else would be good to go to learn it, but I would recommend trying to put together a very simple proof of concept app (a couple of modules with views across a couple of regions sending events to one another should be reasonably easy to knock up) to understand the basic concepts.
