Prnt screen for screenies in win 7
24 Oct 2005
North East
source
To everyone still having a problem with Print Screen, and none of the proposed solutions work: I have your answer!
I recently bought a brand new laptop, and I'm running both Ubuntu 10.04 and Windows 7. I'm a Simmer, and I was getting more and more frustrated that I could not capture the screen on my Sims game so I can share my CC. Nothing anyone on here said worked, and then I found this.
http://www.howtogeek.com/howto/wind...-running-an-application-such-as-a-video-game/
It worked for me, and I hope it works for you all!
Close out of the program you are having trouble with capturing the screen.
Right click on the shortcut of the program on your desktop (in my case it's Sims 2 Apartment Life).
Click on Properties .
Click on the Compatibility tab.
In the middle area of that tab, there should be a bunch of check boxes under Settings. Click in the box alongsideDisable desktop composition.
Apply the changes, click OK.
Open up you program, press on your Print Screen (Prt Sc) button, open up a paint program, paste your image (Ctrl + C) and voilà! It should work! ^_____^
Why did ms have to mess up prnt screen. Easier to just use fraps for screenies now but as i posted above there is a fix for prnt screen now for win 7 users for screenies when gaming. If u wana use it that is.
Just posting cos i know a lot of ppl are annoyed prnt screen key isnt working as it did for screenies in games like when u were in vista or xp.
So you can take screenshots with prnt screen ok, when u use paste in paint or somit it shows the screen ok not just a blank page or maybe ur desktop instead of the game?
