No there's no working kitserver with full functions yet there is 7.0.5 which allows full detail graphics custom resolution tweaks.
There are kits and logo's and chants out but you use afs explorer 3.7 to install them.
Here is a link to the latest kitserver http://files.filefront.com/kitserver+705zip/;9289328;/fileinfo.html
I suggest you join the evo-web.co.uk or soccer-gaming.net forums as all the various patches are available there.
There is even a championship teams patch out so you can play premiership and championship but how that works via the master league is beyond me you'll end up with the AC Milans of this world promoted to the championship.
pro evo 08 has killed my winning eleven life - i used to be addicted to the series but ever since 08 was released i'm no longer into it.
heres why :-
the proper widescreen aspect ratio on 08 is awesome on a big screen, 56" here , but i just hate the game compared to previous PES and WE series.
but the trouble with going back to previous versions is now it just looks so bad because of the poor widescreen implementation, even with kitserver it just looks so ******** now and i just can't stand not being able to see that proper aspect.
on the plus side i'm totally hooked onto NBA 2K8 on the 360 now, phenomenal game.
all i've ever seen is the tickbox in lodmixer for aspect ratio fix in 6.x versions of kitserver
i've seen the custom ratio on 7.x but isn't that just for pes08?
i don't think you understand my problem, the aspect ratio is ok but there's not the same depth of field ie. you don't see nearly as much of the pitch in WE10 as you do in PES08 whether kitserver is used or not.
