sanofi said:Is there a way to update the players and teams for this version?
5ingh said:Yes Google for 'max drive xbox' and theres a company selling it, not sure if its a competitor![]()
You can DL the option files to your PC -> Max Drive -> Xbox
sanofi said:I have the max drive for PS2, I guess that won't work? Is the software different for Xbox?
Also will a normal flash drive work?
EezerGoode said:I dont think it is possible to use the updated kits option files through the 360 due to the differences in memory cards.
That is asuming you are playing the game on your 360.
sanofi said:So theres no way to update the game other than manually?
andybtsn said:Yes but you'll be there eyars changing all the players round...
Wait for Pes 6 next month...
manc said:its fine if you set it to 420p mode
