Pro evo on the internet
14 Sep 2005
I'm just trying to connect my PS2 on the internet while my 360 gets repaired.
I'm running it through my router with an ethernet cable.
It gets to the point where it says "Testing NEtwork Environment"
and then it says the port it's trying to use is blocked
NAT is off and it's running real Ips on DHCP.
Can anyone help?
THanks,
Jim
I had a lot of problems with getting my PS2 online. I remember it being somethnig to do with the software comnig with the networkl adapter not working and the only way I could register mine was via a certain game.. I forget the name now, some 3rd person shooter with voice com.
Anyway before that it was throwing out all sorts of errors so I don't know if that could be the problem. Try setting up the connection from within another game or something to see if that gives any joy.
EDIT: Setting the DMZ to the PS2 IP should work if the above comment does not apply to your problem.
