pegasus1 said:Cheers guys, might order this then.
What exacly do the patches do, i'm not shy of delving into the config file either.
pegasus1 said:, havnt played the PS2 version since PE2.
How well does it work when using a PS2 Pad?
Cheers
Sutters said:PS2 Winning Eleven 10 with english patches > PES5
ScarySquirrel said:The same as it does on PS2, except with easier online access, much easier to get mods for it, etc etc
Just go and buy it, you wont regret it...
Most of the patches dont work online, but with Kitserver you can get all the real kits and use them online, also LODmixer allows you to up the graphics a little bit which is nice
