So I've just sorted the loft in a property ee purchased last year. The insulation was awful and everything covered in mouse droppings, so seems they had an infestation up there at some point. I didn't spot any while removing the old insulation but there also weren't any traps or bait stations which was a little concerning. I've now made the loft all good with insulation and boarding ready for some storage of items. I want to ensure however that any mice remaining if present are killed off, but even if they're not present ensure I've got a proactive measure in place. Just wondering if a couple of bait boxes or traps would be best? Is there any risk of encouraging rodents in if bait is put up there? i.e. creating a problem that might not exist or will it be fine? Lastly I might want to do the same in the internal garage as there is a gap under the garage door and above a side window which needs to be sorted. It's an obvious ingress point to the property, so again thinking of being proactive here, does that make sense?
Thanks as always
Thanks as always
