prob with dual display on a 6800 le
24 Oct 2002
Hi
I have a 6800 le and all is good until i tried to connect it to my tv using a s-video cable. For some reason i cannot get the tv to be set as a seperate display. I want to be able to keep the tft monitor as it is and have a blank screen for the tv that i can drag dvd programs onto.
I could do this when it was connected with a VGA cable but now it connected with an s-video cable i can ony clone or span the display.
Is there any way round this.
I am using latest drivers and no i cannot use a vga cable again as the computer has moved.
Thanks in advance
The problme you have is the computer is not detecting the tv as a second display.
You can try forcing device detection using the nvidia tools, and see what happens, other than that i'm not sure
