Probably a silly question but...
19 Jul 2004
Shoreham by Sea
Do the dual core A64 socket 939 processors work in all socket 939 motherboards? or do you require a special motherboard which supports dual core processors?
Asus A8V
Had a quick look on the ASUS webby and it does mention being able to use Dual Core CPUs so I can only assume it should work :|
Yep just get a newer BIOS if yours is rather dated. Sometimes it won't boot with a new revision or model of cpu, had this problem with a bunch of AV8 (Abit) boards that i had for a client order, all the cpus i ordered were Winchester 3200+ and they would'nt boot, had to use a 3500+ Newcastle to flash to a new BIOS to get things working. With my A8N Sli it had a rather old BIOS and my 165 was recognized as an AMD Clawhammer family with no dual core :D BIOS flash sorted that out, so it can vary in its behaviour whether it'll even boot or not.
Copied this from asus website :
- Supports AMD Socket 939 Athlon 64FX/Athlon 64 X2/Athlon 64
- Supports AMD 64 architecture that enables simultaneous 32- and 64-bit computing
- Supports AMD Cool 'n' Quiet™ Technology
Just update the latest bios and you should be fine.
