Caporegime
- 13 May 2003
- Warwickshire
Hi
I'm trying to find the simplest way to take a permanent and switched live off my lighting circuit for an extractor fan. I was going to splice into the feed in the loft and use a junction box of some kind. However upon opening up my light switch I found an interesting arrangement, including a single core red wire and a twin and earth but with two brown cables (thinking about it, is this sleeving?):
What's likely to be going on here? Have they used the light switch as a junction box to take a permanent live off to somewhere else?
I was going to base my wiring on this:
...but why bother with a junction box when I can presumably take both switched live for the fan and permanent live for the fan run-on from the light switch? The only thing I'm struggling with is the neutral back from the fan, but presumably I can run single core flex from the fan neutral to one of the downlight boxes?
Thank you (again)!
Thank you (again)!
. The single core in the light switch goes off under the attic boards somewhere that I haven't yet managed to identify. Must be the landing light but goodness knows why they routed neutral and earth separately.
