Hi all got a question about using a Hauppauage HD PVR 2. Is it necessary that you got to use the HDMI out to connect it to the TV? The reason I ask is cause I am looking to buy one, but the room I be doing it in only has a PC with a monitor and it aint got HDMI.
I was planning on connecting the console up to the HDMI in and use the picture on the PC screen to play the game. I guessing this should be OK, but just wanted to check if I needed to use the HDMI out as well to get it to work. Thanks.
