Probably an easy PSU question.
18 Oct 2002
Derby
Hi there
At work we have a number of PC's with bust PSU's. The machines are about 3-4 years old and I would assume have an ATX power supply. On close inspection these ones have the 20 pin connector but are a bit longer than your average PSU. Are all ATX PSU's the same height (I would assume so with case standards etc). The machines are desktop pc's and not the "tower" variety.
Thanks for your time.
Vedder said:
Hi there
ATX have had many changes in standard but may vary in size of depth. However, all have the same screw orientation at the rear so they can be place in any case. Should be fine.
check this out http://www.pcguide.com/ref/power/sup/form_ATX.htm
actually i'm not sure thats right.. i have a not that the Height is 244mm and 305mm Wide or 244mm wide for Micro ATX . There's is no stnd fo Depth irrc..
I may stand corrected of course.
I'll check the ATX revision - nothing there???
I have a spare ATX at home so I might just bring it in and see if it fits as mine looks like a more bog standard one.
Thanks for your help.
cool.. the size thing has got me curious though.. so i might do some digging around.. I like to know these things :)
