Probably borked graphics card, but...
4 Jun 2003
Fraggle Rock
Well my 4870 died last week - didn't blow or have a fan failure or anything, but I didn't get any picture when booting the PC, not even the post screen, monitor just goes straight to sleep. I know the PC's ok cos I can hear the windows start music. No error beeps from the 4870.
I slapped in an old 8800GT and it boots up fine, so I order myself a new card, a powercolor 5770.
Which does exactly the same thing as the 4870 - monitor goes straight to sleep as soon as the PC powers on, never see a graphics card flash screen, a PC post screen or anything.
I'd just assume it's a borked 5770, but it seems a bit suspicious that it should act exactly the same way as the old 4870. Anyone come across anything similar? I hadn't made any hardware or software changes, running Win7 64bit.
If you are using a DVI connection try just a normal VGA connection to the monitor.
Yep, this did it. Weird, I'm using a normal DVI-D connector. Maybe it's not quite standard spec or something. Seems to be a fairly common problem from reading the AMD forums too.
Going to load up the proper drivers and see what it looks like. Don't really want to be stuck with a vga connection though :(
Could be a faulty cable then mate or pins bent in the dvi port on the screen?
Right, really weird :
I plug the DVI cable into the other port while the VGA cable is in, then plug the VGA cable out, and it works fine with the DVI :)
I'm afraid to reboot my PC now though :eek:
Edit - yep, reboots fine now with just the DVI cable, very odd.
Thanks for the help all anyway :D
