25 Jun 2015 at 21:15 #1 marcus2704 marcus2704 Associate Joined 7 Aug 2005 Posts 358 I bought some Teamgroup 2666MHZ memory recently, and noticed in HWINFO it shows as 1333MHZ. I was expecting 2666, is this normal?
25 Jun 2015 at 22:10 #2 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 19,211 Location West Side Yes its correct, its double data rate memory so 2 x 1333 = 2666.
26 Jun 2015 at 12:02 #3 pandem0nium pandem0nium Soldato Joined 5 Dec 2010 Posts 3,212 Location Solihull Not if you read the bottom corner where the memory clock is 666.7 which = 1333 effective. OP: you need to enable XMP in the bios for it to work at it's rated speeds.
26 Jun 2015 at 12:21 #4 marcus2704 marcus2704 Associate OP Joined 7 Aug 2005 Posts 358 pandem0nium said: Not if you read the bottom corner where the memory clock is 666.7 which = 1333 effective. OP: you need to enable XMP in the bios for it to work at it's rated speeds. Click to expand... Many thanks for your response, I will look at this later on tonight.
26 Jun 2015 at 12:42 #5 pandem0nium pandem0nium Soldato Joined 5 Dec 2010 Posts 3,212 Location Solihull No probs
26 Jun 2015 at 22:26 #6 marcus2704 marcus2704 Associate OP Joined 7 Aug 2005 Posts 358 Enabled XMP, now it says 1333Mhz. I take it from that its all sorted
