Probably really dumb DDR5 question
18 Dec 2008
Liverpool
If I get a kit of DDR5 with Intel XMP profile, will the XMP profile show up on AM5 in the bios as normal or do I need AMD EXPO for that?
I'd like to buy this kit G.Skill Trident Z5 RGB Series (Intel XMP) 32GB (2 x 16GB) 288-Pin SDRAM DDR5 6400 CL32-39-39-102 1.40V Dual Channel Desktop Memory F5-6400J3239G16GA2-TZ5RK (Matte Black) sold by a competitor
on the Asus ROG Crosshair X670E Hero (Socket AM5) DDR5 ATX Motherboard
If you installed a memory kit with XMP profiles on an AMD chipset motherboard, or if you installed a memory kit with EXPO profiles on an Intel chipset motherboard, then you may see another name, such as DOCP or A-XMP.
Assuming the same as ddr4 mate
My ddr4 has xmp profiles
On intel board my bios shows xmp
On one of my am4 boards it showed xmp (Gigabyte x570 ultra]
On my new crosshair viii extreme it shows as docp
On all of them enabling whichever it's called set the ram
To the same speed anyway
Trident z5 neo and flare are expo certified far as I recall
