Problem accessing Google
10 May 2004
Middlesex
Hey guys,
Got a bit of a weird problem.
Google will not load up properly. The page will kind of half load sometimes but that's it. If I enter something in the search field and press return it won't load any further.
Had this problem for a couple of weeks.
Got 3 computers accessing the net through a router and they all have the same problem.
Have run the usual adaware/spybot scan and a virus scan (nod32).
Any ideas?
Wouldn't be surprised if its Talk Talk playing up.
Thanks a lot.
Yea, that link works. It's definitely talk talk then?
Thanks a lot.
Yes, You have acctually accessed the page without going through your DNS @ talk talk. Like a direct link to google servers without having to go to talk talk's DNS server. I suggest maybe you could try this?
http://www.opendns.com/
Hope this helps.
