Problem after replacing sound card
24 Aug 2009
Had to get a new sound card due to upgrading to wimdows 8 and driver issues.
The old sound card is sandwiched between 2 gpus that are watercooled and it was a total ballache to get out!!! In the end, I had to rag the thing out instead of dismantling my loop etc considering I put it in fine in the first place.
The computer now will just shut off when trying to load into windows. However, its not all the time, 15% of the time I can get into windows. I think ive damaged the motherboard in the process, but cant see any scoring on the motherboard. Ive tried different ram, hdd and gpus without avail. Last thing is to try I guess in the psu.
Anyone shred some light?
Thanks, Ben.
Sorry for any mistakes in the post, wrote this on my phone.
Ill have to check but I think they are all the way in their slots but will double check!
Worst comes to the worst, be upgrade time, but always on it 24/7! If it is the mobo, then its lasted a good 5 years, and will have to upgrade just after christmas!
