Earlier while filling up the windscreen wash in a bit of a hurry I managed to spill a bit on the car battery. On starting the car the battery and oil warning lights didn't go out, the brakes didnt work and neither did PAS.
After mopping up a bit of residual water everything seems back to normal except for the backlight of the clock/climate control unit, which isn't working.
Is this likely to be a blown fuse or something that will clear itself up? Or something else?
Car is a 2001 Accord.
Thanks muchly for any advice.
Quite likely if you shorted the battery out!
