problem, any ideas?
22 Jul 2010
Got a new xenomorph build from OCUK over the weekend. Installed windows and got everything running just fine, then after about 5 hours of use (browsing, couple of app installs) it randomly switched itself off quietly and wont switch back on. Unplugged it and waited a few mins, plugged it back in and switch it on, the fans and lights flick on for a very short split second but it still wont power up.
Any help or ideas at all would be appreciated ;)
ah just an update.. Called OCUK tech support. Guy suggested trying to turn it on after removing the GPU, and it did indeed start fine without. RMA was given and the faulty gpu is posted back to OCUK. Just wondering if anyone can comment on what usually happens, will I get a replacement card of the same model or a different similar spec card?
