- 12 Jan 2006
My PC had a bit of a hiccup today. I was playing planetside when my PC became unresponsive and then froze. I pressed reset and upon restart the machine posted but was making a clicking sound. Windows then entered the HDD diagnostic where it checks for bad sectors but skipped through the diagnostic without completing it and went into my desktop. The machine then made a beep beep beep sound countinously but the clicking had gone.
Now my first thought was that the HDD was dying (it was only 3 years old but had had a lot of use) so I went and brought a new one. upon replacing the HDD and turning the machine on for the first time it now made a single continous beep and according to the MSI diagnostic panel I had a problem with my processor. So I checked the processor and reseated it, same problem. I tested the memory in my brothers machine and that worked fine. I then checked the Graphics card and got the same problem. So bottom line my graphics card is borked.
Problem is the original error does not look like it was the graphics card as I had no graphical errors or artifacts (I had a 9800XT burn out on me so I know what a dying Graphics card can look like).
Also I dont think I can Return my 6800GT as I had replaced the heat sink with an Artic Cooler and so would have voided the warranty.
I am going to keep an eye on it for the time being but I need a replacement graphics card. I dont want to spend a huge amount as I am going away in 8 weeks to Thailand and will be there till next year. I do need a card that is capable of running planetside with some eyecandy. A 6600GT would be nice but I do not want to spend more than £100.
My intention when I return is to have some money left over and get a nice Conroe based system but I think I will be buying a complete system instead of building it so I have a warrenty to fall back on if it goes wrong.
for those of you trying to troubleshoot this my system is:
Motherboard: MSI K7N2 Delta ILSR NForce 2 Chipset
Processor: AMD Athlon 3200XP Barton Core
Graphics: MSI 9800GT 256DDR2 with a replacement Artic Cooler (now Dead)
Memory: Corsair PC3200 Low Latency Matched Pair 512MB (total 1GB)
HDD: Seagate Barracuda 7200.7 80GB Serial ATA HDD
PSU: Zalmans 400W Quiet PSU
My system is Windows XP home with SP2 and all patches.
Just as a quick edit I am using a back up GeForce FX GFX atm and the PC is running fine once more.
