Got myself in to a slight issue. Had to replace a motherboad for a fujitus pc with a different make/model. The cables for the fujitu case are all bundled together, I had the idea of cutting them up to plug onto new mb but made a mess of taking the cables out of the black connector. The metal ends that are on the cables that go in the black connector are now fubar and go in but don't stay in when I try and slip them on the pins.
Is it easy to replace the metal ends, they are that small its almost impossible to fix them so I'm thinking better to replace.
(Its the power/hd/mic & speak internal cables).
