Problem displaying in 120mhz
Permabanned
8 Dec 2008
East yorkshire near hull
Hello, i have a 3d monitor 120mhz , when i set the mode to 1920x1080 120mhz, my display gets messed up it goes blury and text becomes unreadable.
Anybody get any ideas why, i recently got a new mobo Z68 chipset could the onboard graphics controller be messing with it. My grpahics card is a 480gtx and i never had this problem on my old motherboard.
Are you using a dual link DVI cable?
You need to for 120Hz.
If you're just using an old cable it may not be dual link.
Your monitor was likely supplied with a dual link cable.
