Hello OCers,
i had an issue with my custom-built pc for a while now and i was not able to solve it in any way, leading me to suspect a problem with my motherboard.
my problem is the following: when i plug in a USB device which requires driver installation, i get the annoying "USB not recognized" message and "unknown device" pops in the device manager.
in more details, the USB devices i plug in fail to enumerate properly (getting listed VID_0000&PID_0000). other devices with no drivers (like certain mouses and keyboards) work normally. the devices giving the "unknown USB device" message in my pc work normally when plugged into another machine, excluding the possibility that the devices are not working properly.
both USB 2.0 and 3.0 ports are giving the error, and same for mobo ports or front hub.
should't be a power problem as i plugged in a device powering off USB cable and was powering properly (in windows also i get the message that each hub has 500mA available).
my motherboard is a MSI Z87-G45 gaming edition, and i'm running win 7 x64 enterprise (iirc, i can produce a dxdiag later)
here is a list of all the solutions i tried so far in order of complexity (and nothing worked so far):
- resetting the pc
- turning off the pc and and letting it off for a while
- deleting infache file and similar solutions about inf files
- updating drivers
- registry editing
- updating bios (as i read some MSI mobo had bios-related issues with USB which was fixed in a later release of the firmware)
- re-installing OS after formatting followed by clean install of the most updated drivers.
after trying all these solutions i'm starting to get afraid the problem lies in the USB hub in the motherboard. my PC started having those issues after i moved to another house, maybe something got damaged in the process. i tried also to disconnect the front hub (as i was reading that sometimes can create issues).
if anyone has any suggestions or help imputs will be greatly appreciated, as i wrote in the title i'm going mad over this issue hehe. is the first time i'm not able to solve an issue by myself.
also any ideas to test whether this could be a motherboard issue would be appreciated as well
cheers
Leo
- resetting the pc
- updating drivers
- registry editing
cheers
Leo
