problem flashing 6950 to 6970
30 Dec 2010
Im trying to flash my 6950 into a 6970 via win 98 dos. everytime i type the command atiflash -f -p 0 6970.bin it says file not found ???. but the file is on the flash drive. Can anyone help ?. ive tried using different BIOS but still the same. maybe im not putting the bios on the flash drive properly ?
Well according to the sticky (which I followed to do my card) here:-
http://forums.overclockers.co.uk/showthread.php?t=18221844
And my post within the sticky showing the command I used:-
http://forums.overclockers.co.uk/showthread.php?p=18552244&highlight=username_Firegod#post18552244
And according to Techpowerup article:-
http://www.techpowerup.com/articles/overclocking/vidcard/159
The command to use is "atiwinflash".
right ive unlocked the card now using the automatic in that link. But now the problem is i uninstalled drivers and when i go to re-install drivers it blue screens ? =/. Anyone know what i can do now ? xD
It sounds like it doesn't like the flash. Try removing and uninstalling the drivers in safe mode? Maybe try a clean install of windows as well. After that I reckon you should be looking at restoring the old BIOS.
Got the drivers installed now ran it through xp mode. But im bit worried about this random drivers stopped working shiizz. Seems to do it a lot on firefox but not so much on explorer :S
