Problem following overclock
13 Aug 2009
Hi All
please can anyone offer advice on the following problem.
system spec.
Intel E6400
Gigabyte EP43 -DS3
Kingston HyperX 4GB DC PC8500
BFG GEFORCE 9800GT
antec Power 500w
Artic Cooling
the system is easliy overclocked to 3.5GHZ with max CPU temp of 47c underload, which i'm really happy about. the system is rock stable in windows vista 64x, however, when the machine is powered down (turned off) the darn thing will not reach the post screen, the MB has to reset the CPU settings to default for it to POST, then i can enter the bios and overclock again, the machine then works fine, until its turned off..
its getting on my ..............
thanks
craig
