Hi.
I recently bought a 16GB flash USB drive from eBay which I believe is faulty. Initally, it seemed to work, but as I tried copying a large file on to it, it caused an error. I removed the device and plugged it back in, and now it appears to be unformatted. When I try and format the disk to access it, I'm told that the disk is write protected, so cannot be formatted.
Does anyone know of any methods I can try using windows, or some specialist software to attempt a fix?
Thanks!
Thanks!
p), so when you tried copying something larger than the physical size of the flash drive, it died. At which point many unsuspecting people would have left feedback etc. It's illegal and you should report the seller to eBay.
