The mobo is an elite k7s6a rev one who's manual is here:
http://www.ecsusa.com/downloads/manual_k7s.html
The casse is generic - no manual. It has two 5 hole USB connectors marked USB1 and USB2 the lead from the front USB ports (the rear USB pots work fine).
The USB connectors were plugged into 'USB3' on the mobo - i have also now tried them in LUSB1 and LUSB2.
Whetever combination Device Manager (WinXP) shows an unknown device. If i uninstall and then reinstall it finds a USB device but can't load it properly (says no drivers loaded)
What i am still not sure about is what gets plugged inwhere. For instance all the USB locations on the mobo have 10 pins (2x5) - however are they supposed to support just one USB device or 2? I assumed 2 as the case USB connectors only come with 5 pins each.
I found this http://www.pctechguide.com/tutorials/MBoard_USB.htm that seems to say each USB connector should be 8 to 10 pins - so how come i only hvae 5?
I have tried reversing the way i put on the connectors but no change.
Thanks
Diss
Thanks
Diss
